So I have had the Pro Pipe since July 2014 with the standard baffle and installed a canned map with my FP3.... ran great!
I decided to run a competition baffle in Dec 2014 and installed another canned map for this baffle... it ran good, but not great. I Liked the extra 'noise' that the flow-thru design produces but I lost a bit of bottom end and gained a lot on the top due to the decrease in back pressure.
I also had a bit more decel popping thru the exhaust and decided to run an autotune session for 650 miles. I gained a little more bottom end, but wasn't 'truly' satisfied with the end result.
I went back to the standard baffle and canned map of my initial install and after running both, this is the best setup for a STOCK 103 and full stage 1.
I can only figure that the comp baffle would be much more suited for a bike with a bit of motor work... cams etc..... Don't get me wrong, it's a great addition to the Pro Pipe, but you need a bit more work to gain the full performance value of it... so it's on my shelf.
