Tribar l rear light hlp
Thnx Hulkss. The found the mentioned "break open and refit yourself option" also on the internet. That seems the only bypass due to the fact that the dummy HDI tribar has a input as the US setup but an different output settings going to the blinkers/stop on the rear fender. The 2015 does not carry the central running/breaklight on the rear fender any more. I am reluctant to fumble with the original stock item. When I screw things up i cant get a stock one to replace it...
Anyway. Thank you all for trying to help me out. I'll just gonna wait till some smart dude builds a plug and play swap item ;)
Tri bar light hd international models
Here is how i did install the tri bar light on my street glide 2014 hdi model.The light is empty here in europe.Take off the empty light from your bike,take off the smoked lens its glued.buy a tri bar light from biker choice part nr 482761 oem#68358-07 take off the smoked lens on the new tri bar light remove the led lights in side the new light and install it to the old light, first you drill a 10mm hole on the left side of the old light for the cables.Order cable from harley davidson part number 69200772 install this under your seat there is tree cables that runs to the tri bar light. Install all back on bike and you are done.If harley dont make a tri bar light make it your self!!!street glide need some extra brake and running light.See harley led light kit 68000111 for instruction where the wires conect.
