HID 55 watt H 11 bulb
Newbie here.
For those who buy the After Mart headlight. Could you please let me know if you need to buy the 7inch Round Headlight Ring Mounting Bracket? I have the 2016 SGS
HI all, I just installed a Kensun 55 watt HID kit on my 2015 street glide and its incredible.!!! way brighter than a LED Bulb and it turns heads going down the road.. can't be missed.LOL
The only thing I had to do was install a relay and a fused single power wire from the battery to the relay because I got a BCM code I think B2139 and that is a high current code on low beam circuit.. ( the HID on startup draws about 20amps but after that it drops to 3 amps for normal operation)
for those that may not understand how the relay works in conjunction with the HID kit..well here it is.
I used a 5 prong relay.( but a 4 prong works too ) cause that's what I had on hand..
The prong /terminals are labeled #30, #85, #86, #87, 87A ( in my case 87A is not used)
I used 85 as the ground for the relay.
I used 86 for power from the factory head light plug (using the adapter provided with kit) to activate relay (open / close)
I hooked up fused wire from battery to 30
I hooked up wire from 87 to power input wire to HID box.
The relay allows the head light circuit to see something and it takes very little amps to activate relay..( so no over load) When the relay closes the power from battery is sent across 30 to 87 to HID giving it the proper clean voltage it needs. my volt meter on bike shows over 14 volts and even with High bean (stock bulb) and low beam HID on at same time..
The wire from battery passes through the wire channel under tank to right fork area. The relay and HID kit are mounted on black metal plate above radio.. and no interference to the radio.. as a added touch I placed wire lume over all wires. Gives it the clean factory look.
I,m very pleased with it But that's me..
