Freedom Performance True Duals
yegg
Sep 18, 2015
235
So I'm getting ready to pull the trigger on the Roland Sands Clarity cam cover. Since I have to drop the exhaust to do this, I'm thinking of going ahead and switching from the Vance and Hines Dresser Duals to the Freedom Performance True Duals. I want to do this as some day I hope to put an electric center stand on and I can't have the cross under pipe for that to work. My sled is a 2015 and I am wondering if anyone has a Rushmore model with the Freedom Performance True Duals. I am concerned about the left pipe (rear cylinder) being routed so close to my left side panel and left passenger peg. Can anyone speak to my concerns? Another question that just hit me is if I am stuck with a passenger peg or can I eventually go to passenger boards? Thanks
they dont heat up the side panel and yes you can run pegs or floor boards, i have used set if you are interested
attachment.php
attachment.php
attachment.php
attachment.php
one mounts to the starter bolts the other mounts to the tranny like all other pipes
So I have a question. I have a 2014 SGS and want to make sure the freedom true duals fit. I like the look of the header going done the left side. I want these. Just want to make sure they will fit.
TIA Ned
