Going off to do my speedo shortly.
Found it under the map that is loaded on the bike under General.
I've been through it 3 times now, doesn't show up on mine, strange. I'll keep trying.
EDIT: OK, after trying 4 times to sync my phone and not being able to see it, I deleted the app off my phone and reinstalled it. Presto! Once it drys out here I'll take a run and see how it goes. Says it will calibrate once you reach 60mph, then you'll be able to accept it and reflash.
I found it, had to go to my app and force it to update.![]()
make sure you connect to the FP3 and update the firmware of the FP3 itself... not just the app....
Give them a call tomorrow....patience. I still gotta get a tuner for my RGS and FP3 won't work for my 120.. I called 3 times and 3 different people.. so lookin at about a grand for tuner and dyno since nobody can't give a word of confidence for a good tune for PC or PV... I could go Thundermax.. but it's a grand by itselfEven after the firmware update, it doesn't seem to work. Sadness. I did it 2 times and each time it still says speedo is off by 4.3%. Maybe this isn't ready for prime time yet. Got all excited for nothing...
I was able to calibrate mine today. Mine was 4% off![]()
I will check it again in the morning on the way to work and I'll let you know.But if you do it again will it now show the correct speed or will it still say the speedo is off. I guess we were expecting if the process is done a 2nd time, it will basically show it is not needed.
You are correct, I checked it again this morning on my way to work and it still said it was 4.5% off. Let me know if you get in touch with V&H. ThanksBut if you do it again will it now show the correct speed or will it still say the speedo is off. I guess we were expecting if the process is done a 2nd time, it will basically show it is not needed.
Did you flash it after it calibrated? Just wondering if it works the same as making a throttle adjustment.... those must be flashed to take affectYou are correct, I checked it again this morning on my way to work and it still said it was 4.5% off. Let me know if you get in touch with V&H. Thanks
