And the hits keep on coming.
I checked my engine oil the other day and found it VERY low. It took two quarts to bring it back up to where it should be. I have no been able to check the primary yet to see if that is where it is going. I mention that as I do not have any ground oil and I do not think I'm burning it. On the other hand, I would have thought that 2 additional quarts in the primary would have had some affect. Am I wrong about that? I have read that excess fluid in the primary causes clutch slipping and/or difficulty finding neutral. I have neither symptom. I have noticed that my oil pressure seems to be on the high side. What should it be for a stock motor (except for stage 1)? Next weekend I plan to remove the derby cover and see where my fluid level is. If it is much higher than normal I am going to tear down the primary. I really don't want to do this again any time soon so what seals should be replaced while I am there? Also, is there another possibility for my disappearing oil?
It just seems like everything is going at 50k. :
Ride safe.
Ride safe.
