I have been looking around some different posts and there seems to be one particular fellow that goes by Doc that appears very adamant that there WILL be a sensor confusion and tuning will be a problem with a de-catted stock headpipe. I have a 2015 103 c.i.. that I put a de-catted headpipe in with Full Boar 3 1/2 slip-ons and the fl-vied's and a stage-1 air cleaner using stock a/c cover. So I rooted around in my headpipe I took off and it doesn't seem that the sensors are able to read the same head information because they are separated by the tubing for a few inches before they are in the common collector where the cat used to be located. From there it seems to be at least 8 inches further before the crossover pipe in which the larger portion of exhaust actually continues straight out into the muffler.
I switched to 2" baffles from the 2 1/2" baffles that I had ordered with the slip-ons (sounded awesome), but took away the bottom and mid quite noticeably.. I have my VIED's set at about 65% and have checked plugs after a couple long rides to see that they are no longer paper white, but a bit tan and gray now. It takes a bit longer for the back cylinder to cut out at lights and my low-midrange power feels considerably stronger than originally. The sound the pipes make is DEEP HARLEY and not sewing machine. lol
So the final comment on this new thread is I just don't feel or hear anything negative with the de-catted headpipe. If it was on a dyno with stock de-cat or true dual than maybe there is some small difference but I am pleased with it as it is. For now.
