I have 2 things I need help with. First, I was riding home from work the other day, anything around 3k RPMS and above was met with a terrible vibration coming from what I believed to be the engine area, I had to make it home so I kept riding very modestly. Eventually. I was pulling a hill and something from the primary area popped really loud and she smoothed right out, vibration gone. Since then, it's made a clunky noise from the primary area but no vibration. I decided to look, that's where the second issue surfaced. I pulled the derby cover to have a look at the clutch pack and there was some metal shavings on the inside of the derby cover, that's when I noticed that there was a LOT of fluid around the clutches. So I drew it out to "normal" levels and noticed it smelled of transmission fluid, so I checked the transmission fluid, it was about half a quart low. I pulled about half a quart from the primary so I'm definitely having some transfer. Now, any insight to what could be the cause of either would be helpful. I know this is kind of a long, run-on post and for that I apologize. It's a 2015 FLHXS with the 103.
