Tail light Plasma Rod Wiring Help!
CrBear
100
Called Custom Dynamics but I think she was having me look at the wrong harness..
She had me open the left cover and I see two wiring harness. Top is off white and below is grey.
I was searching for the blue/purple (and looks like two of them) that connects to TFC Red and supposed to be a solid Blue to attach to the orange of the TFC. Don't see a solid blue..
Then she says the harness cover is black.. not a black on the side. there is one under the seat.. is that it ??
Thanks
Best thing to do is to get on their website (Custom Dynamics) and click on contact, then go to the bottom of the page for technical support. You can either call or email tech support.
Good luck
Thanks
I tried the black connected under the seat (search web and found some info). That Worked for left (thigh) side. Run/Turn/Brake.
Right side isn't working but taking a break.
I left word for tech support (but she said the only have a 4 hr window!)
Got her fixed.. It wasn't too bad.. Better when your not steered down fox hole looking for an armadillo..
What fixed it?which plug went where?
The connection was under the seat, not on a harness under the side panel. She was looking at the wrong bike model. If you are installing, I'd call them, they are pretty good (once they get the right bike). PM me if you need help with it
Clive Miller
