2016 street glide 103. Added screaming eagle hi flow exhaust - 2 inch o.d header pipe no cat. Screaming eagle street canon with cats relocated in mufflers. Screaming Eg pro tuner. Screaming eagle stage one intake.
Problems- to quite and pop on deceleration here and there.
Good numbers on dyno but dyno also said running lean.
Harley dealers can not tune it recommended to other shop for dyno tune. $425.00.
What would you do or consider the best option ( money not issue )
1- scrap SE exhaust go with other ( which one and type) ?
2- scrap tuner for one that learns ? Which one ?
3- cut out cats from muff weld and try to tune with SE or other tuner ?
Could try to resell whole system on e bay
Could not find slip on's with 2" od for header
Might be able to find slip on's and open up to 2" if split weld.
Any input thanks
Any input thanks
