Redoing Autotune
yegg
Sep 18, 2015
235
If I change out my air cleaner, should I redo the autotuning from the FP3?
Yes if your changing the air filter I would. May not be much difference but a little always helps.
I figured as much. I think I found an air cleaner I like better than the RSD Clarity and it should give me more leg room on my board and make it easier to hit my brake peg. Now I just have to save (hide from the wife) the money.
Which air cleaner did you find?
For leg clearance I don't think you can do better than the stock cover.
It is a dual cone that faces forward. It is made by Wimmer.
Clive Miller
