LRS Led combo kit
Spike
26
Anyone here using the LRS LED headlamp/aux light and if so what are your thoughts?
Thanks
Yup I have them. I'm quite happy with it.
Be prepared for some install complications though. The hole that holds on the trim ring on mine was not tapped (8-32 if I remember right) also mine didn't come with a h4 headlight harness so if you have the dual halogen headlight now, you'll need that. I've attached pictures of the high beam of the stock headlight with stock bulbs, stock headlight with Led bulbs and again with the LRS headlight. All are just headlight, not passing lamps as I got them after I took the pics with the stock headlight.
What order are the pictures in? Top is the LRS light?
Damn phone...
Top LRS
Middle stock with stock bulb
Bottom stock with Led bulb
I think I'll give em a shot, sure beats the hell out of spending a grand on H-D lights
Clive Miller
