Help
Antoneyo
Ordered some 13" cyclesmith Apes and wondering what all do I need and what I can still use from the stock setup. It's going to be for a 2012 street glide. Anyone done this before and still used factory parts or do I have to buy everything new?
Thanks
Sent from my SAMSUNG-SM-G750A using Tapatalk
Sorry can't help, I have a '14 and needed wiring harness and new brake and clutch lines. Call Mark Dicks with Low Life Industries he will be able to answer that and set you up with all your parts. (813) 758-9720
Bryan,
I too have a 14 S.G. and all I needed was wire extensions for my controls. I was able to use the stock tbw throttle and clutch cables.... the 2012 s.g. is for a friend of mind
Help
I have a 15 SGS with 13" apes and stock cable. This is the absolute max to use stock cable, yes it is very close but just a little re-routing and it works perfect.
Clive Miller
