CD Bullet Ringz
yegg
Sep 18, 2015
235
Right now I only have CD Bullet Ringz installed on the front. Is there a way to keep the outer ring on all the time? As it is now, when I hit a turn signal, the outer LEDs turn off and the signal flashes.
The side that is not signaling a turn does have the outer ring remain on.
Thanks.
Not sure on this one. They are designed to work that way so the rings shut off and the yellow blinker shows brighter to get cagers attention.
Maybe some electrical wizard will know.
I have read that this is a legal requirement for front lights.
CD explains this on their site.
Different question. I installed the LED tail lights and magic strobe yesterday. It was super easy, increased the brightness about 500% and really gets your attention when it flashes. However when I hit the turn signal, the dash light for the turn signal flashes fast, just like on a cage when a bulb is burned out. Lights all work though. Anybody else have this problem or know a fix?
You may need a load equalizer? Some years do, but I'm not sure what they are? I had to put one on my 2012. Chris
Check to make sure the bulbs are installed correctly.
I might know of someone that had the same issue and that is what it was.
Thanks, I will check into that. Did they have the same issue? Blinkers worked but the dash light was blinking fast?
So came home, checked, and the connections were good. I turned on the hazards/flashers and walked around the bike. Turned off the hazards and pressed the turn signal, and holy buckets, it worked just fine. Easy fix I guess.
Clive Miller
