Bulb change?
N
norcalsvt
Guest
Wanted to see if there is a light bulb replacement for my 14 sgs. Looking for more light output, and a whiter beam. Don't really want to spend the money for an led light, I don't drive very much at night so I'm just looking for something relatively cheap but better then stock. Thanks Rob.
Unfortunately the cheapest option up front is the high end Sylvania bulbs but I've tried them and they die fast. I think mine died after 4 months which is not OK with me. Even if you don't drive at night, more light during the day is good as it may help make you seen in someone's mirror (assuming they even look). If you're willing to spend a few bucks, fuel moto has their LEDs for ~$150 which includes high and low beam. Alternatively you could try finding a hid low beam and/or high beam. I can't speak to their quality but I've seen kits around $100.
Thanks for the info. Do all h11 bulbs fit our headlight? Also isn't the hi beam a h9? Will replacing both with the h11 work? Thanks.
I put these on my bike they caused too much static to listen to the radio my antenna is under the seat may be the cause. I now use the JW Speaker Evo 2, an excellent light save your money and get one of these.
Didn't realize I had wasted my $$$......thanks for the enlightenment
Clive Miller
